I got this via PM, and I think it's relevant to our discussion here:
I read your explanation regarding hydroplaning. I think it's possible that you have made an error.
I haven't studied tire design, but I have studied pavement design. In our pavement design classes the pressure on the pavement from a vehicle's tire was always assumed to equal the tire pressure. This is true if the tire sidewalls carry no load. Of course they do carry a small amount, but it can be ignored in most cases.
The result of the above assumption is that if vehicle weight is increased, the tire will flatten out enough to create a contact patch large enough to carry the new load. Pressure on the pavement will still equal tire pressure. The new, larger contact patch on the pavement will negate any advantages gained from the heavier vehicle.
The speed at which a tire will hydroplane is a function of many variables, but I doubt that weight is one of them.
I have noticed that the formulas used to calculate hydroplaning speed do not account for any tread pattern on the tire. This would lead me to believe that tread pattern doesn't matter, but I doubt that this is true, since tire designers have created some tread patterns that do better than others on wet pavement.
I'd be interested in your sources for the discussion on weight.
I don't have any sources for my info, just my own fallible reasoning.
Consider a bass boat planing on top of the water, or idling through it slowly. When the boat is idling throgh the water, it must DISPLACE that water in order to move there (since physics tells us that two things cannot occupy the same space). If you add weight to the boat, it sits lower in the water, thus requiring it to displace more water.
Now when the boat is "on plane" it isn't displacing the water anymore. If the boat is moving FASTER than the water can be displaced, it will rise up out of the water and "plane out". Because the water has viscosity, it takes time for it to be displaced. IF the boat is moving faster than the water can, it will plane out.
Now what if you add weight to the boat? Well, in order to plane out, the force of water against the hull must be greater than the force that holds the boat down in the water-- gravity. So when we add weight, we increase the amount of force that the water must generate in order to overcome gravity.
This is why weight matters. All else being equal, a heavier wheel (one with more weight on it) will tend to plow through the water instead of hyroplane.
This is a popular myth-- that the AIR in a tire carries the weight. You CANNOT take the area of the contact patches and multiply it by tire pressure to find out how much load is on the tires. This is because the TIRES carry the weight-- the air is there to ensure rigidity of the tire.
Consider two tires- one from a bicycle, the other from a big rig trailer. Both are inflated to 70psi. The bike tire carries 100 pounds at 70 psi when the tire is 30mm wide. That means that the contact patch is about one inch wide, and probably over an inch long. It seems to prove that the air is supporting the load, right?
What about the truck tire (a 275/80R22. 5 LRH Michelin XZA2), which is 10. 9 inches inches wide and supports 8300 pounds with only 70psi? If the "air" theory was true, the contact patch would have to be over 118 Square inches. With a width of 11 inches, the contact patch would have to be over 10 inches long. Well, that seems reasonable enough.
But what about the tires on my truck? At the maximum rated pressure of 80psi, the weight limit is ~3400 lbs per tire. So, the air theory gives us 42. 5 sq inches to support the weight. The tire is (265/25=)10. 6 inches wide. So our contact patch is only 4 inches tall? Not quite.
What about when I air down for off-roading? My tires will handle 10psi up front. To support my FAW, I would have to have over 200 square inches of contact patch! Given the tire width of 10. 6 inches, that means the contact patch would have to be almost 20 inches long!! That's not going to happen on a 31" tire.
In short, don't be fooled about tire pressure and hydroplaning. Weight matters when it comes to hydroplaning. And your TIRES support the load, not the the air within them. The air just makes them more rigid so they can do their job.
Justin
