Last November I setup a personal weather station and mounted my anemometer to a steel pipe mast that is 33 feet high. This mast is mounted to a metal semi trailer. I have 240v/100A power running from a mobile home load center to a sub panel in my shed. From there the power runs to a second sub panel in the semi trailer. Yesterday I bought and installed grounding lug bars for these sub panels so I could separate the grounds and neutrals as the panels didn't come this way. I removed the bonding screw that was in the first sub panel.
This evening I sunk an 8' grounding rod and ran #6 copper from that into the last sub panel. I bonded the #6 copper to the semi trailer on the way up to the panel to give the anemometer mast a good ground. I ran the in-line anemometer surge protector #12 AWG ground wire into the panel ground bar. I may sink a second ground rod at some point as well.
My concern is having this lightning rod, um I mean mast tied into the home system. If there was a direct hit could this cause damage or would it go to earth ground first assuming I have enough rods in the ground. Someone on another forum who sounded like they knew what they were talking about said I should have it all tied together. So the question is should I leave it all tied together or put the mast/trailer on a separate rod from the home system? I just want to see if I can get a few more opinions.
