When I asked, I got a nice note saying the RC 3500 SRW was not available, bases on customer survey data. I guess they think the load range between the 2500 RC (2300 pounds) and the 3500 RC DRW (5000+ pounds)is just fine. I think I am going to like the DRW anyway, but it seems odd they did not offer the option.
As for the 19. 5" wheels; the change from 235's stock, to 225's would not seem to be worth the expense unless it was to change it to an SRW. Those 19. 5" wheels are EXPENSIVE! The ride on G rated tires may be quite a bit stiffer than even the E rated stock tires. Are their other reasons to want to use the 19. 5" commercial tires that I should be aware of?
One of the resons I was considering a conversion to SRW was to use wider D rated tires to soften the ride a little, but they would need to be quite wide to match the load rating of the 235 E tires it comes with - over 3000 pounds each. The new suspension seems to ride OK even with the E tires, so I guess stock will be fine. Replacements for the 17" tires may be hard to find for a while, if I damage one, until more companies start making tires that fit the new Dodge wheels.
