2nd Gen Non-Engine/Transmission hood insulation clips
Engine/Transmission (1998.5 - 2002) engine swap no tach?
Engine/Transmission (1998.5 - 2002) P0126 and P0237 codes. Help!
I am missing a couple of the clips that hold the hood insulation in place. Is the dealer the best place to get those? Thanks!
Unless you can find them in the "Help" section at the local parts house, or the salvage yard the dealer should have them, but like everything else at the dealer stand by for sticker shock.
Thanks for the tip, I been needing a couple too. I've been getting by with a conical tip cover off a gear lube bottle and a small washer jammed up into the hole.
