2nd Gen Non-Engine/Transmission Hood Secondary Latch
Engine/Transmission (1994 - 1998) Gates thermostat
Engine/Transmission (1998.5 - 2002) 5 Speed Shifting Problewm
Just a FYI that involves 2nd and maybe 3rd gens. Went to open the hood, pulled the inside latch, went to the front and no release to be found. At this point I figured I have really lost it as I have owned this truck since new and never had a problem opening the hood. Fumbled around a bit and found a black rod hanging down into the bumper, what the hell is that ?. Well it is the release rod of course. Finally opened the hood after fumbling around with a welding rod and lo and behold the rod was attached with a plastic retainer that broke. I disassembled everything, threaded the rod to 10-24, installed two jam nuts with blue loctite. So if you have not modified yours you should at least source a new clip and replace it while the hood still opens. It is not a matter of if it will break but when it will break. I wonder what plastic marvel is lurking in the break zone next.
Dave
Plastic doesn't get better with age, and certainly not in the heat we live in. Glad you figured out a fix.
There was a re-call on that part years ago. I think that it had to do with the latch not catching, not sure though.
thanks for the heads up.
I just had to replace the similar plastic clip on my 95 Ranger run around town truck, ditto on the plastic parts in doors,and taligates and hoods (slamming/bang)
gtwitch in wyoming
So is dealer the place to go to get a replacement? They probable don't have any idea what it might be with out a picture.
