Competition Hood stack questions..
Competition Has anyone moved their factory hitch forward for pulling?
Off Roading Gorman OHV Park pics
Does anyone have info or pics of hood stacks? I know they seem to be mostly illegal, and will drop the soot on your truck. I'm about to go to a much larger charger, and think around a 6'' tall stack out of the hood would be pretty neat. Are there any kits out there to make it an easy install? Are there any stacks that somehow keep the water out without having a flapper on top? This would be for the 06. .
in my opinion, a bull hauler stack coming out of the hood would look a little off.
also, I think hood stacks are more of a pain to do than you think, a lot of tubing has to be under the hood for the stack to be in the right place. the turbo is pretty far down from the hood, and if you went straight up with the exhaust, it would be in the windshield.
do a search for BigBadDodge, he did a good write-up with pics on his hood stack
do you have access to a welder?
hope I helped you out, definately post some pics if you get it done
I saw a setup on a chevy avalanche at indy last year that was pretty slick. The truck had a Cummins in it with a short stack with rain cap on the turbo. He had a large chrome stack attached to the hood that hid the smaller stack inside. Randy
hope I helped you out, definately post some pics if you get it done[/QUOTE
Depends on where you put the primary. 90* bend straight up and a hole saw and your'e ready for some chrome.
Brad,
I've got a way. Hit me up. Its too dang much for me to type right now. I'm a bit tight on computer time. But I'll be driving for a while.
903 355-4475
~Wes~
turn around!!!
The ones I have seen they have turned the charger around so the outlet is faceing the core support, and the air filter is back by the ac unit. Most guys also run your pipe through the hood, then weld the stack u see to the hood. So your exhaust is inside the stack when the hood is closed. Hope this helps. Justin
I'd like to have something about half that height, and a little smaller around. . Hmm. Would it be better to have a small gap around the pipe as it comes through the hood, or a small pipe going into a big pipe and getting soot in the engine compartment? Hmm. .
