What i need is a positive source that turns on when you blow (push the steering wheel)the horn. I want to be able to hook it up to a switch so i can choose between the stock horn, the electronic air horn, or both. So if this wire you mention is a ground (negative) it will not work for me. My other option was to run wires all the way from the horns back to the cab, but i would rather keep this simple. Thanks again for your fast response. I really appreciate your help.
