Details here: TDR Privileges
Right now my trucks in the shop for the transmission and exhaust manifold. I'm thinking of having them put in the governor spring kit and a set of 191 dv's. What horsepower number should I be making with these along with a #6 camplate, 370's?
I'm not sure the GSK will give you any, but the truck will rev a lot higher, making it feel like you have tons more. The 191's I'm not sure about, as I already have a 215 pump, and I don't and probably won't use them. My guess would be between 300-350 rwhp when you are done, probably closer to 350. I'm sure you will get varying answers on this.
Now that I have tested the Lazer cut DV's, I would like to see someone try them on a 215 pump, keep in mind you WILL have to increase the timing to get the effect.
You had to say that didn't you? Every time I say this is the last BOMB, something else pops up. Then after the DV's, I'll have to go with an HX-40, (or bigger). Does it ever end?
