Engine/Transmission (1994 - 1998) Horsepower
Engine/Transmission (1994 - 1998) Wabco'd?
Engine/Transmission (1998.5 - 2002) 6 speed 3rd shift TSB
Right now my trucks in the shop for the transmission and exhaust manifold. I'm thinking of having them put in the governor spring kit and a set of 191 dv's. What horsepower number should I be making with these along with a #6 camplate, 370's?
Thanks,
Sean
I'm not sure the GSK will give you any, but the truck will rev a lot higher, making it feel like you have tons more. The 191's I'm not sure about, as I already have a 215 pump, and I don't and probably won't use them. My guess would be between 300-350 rwhp when you are done, probably closer to 350. I'm sure you will get varying answers on this.
Jim
Now that I have tested the Lazer cut DV's, I would like to see someone try them on a 215 pump, keep in mind you WILL have to increase the timing to get the effect.
Jim
Thanks, Jim
You had to say that didn't you? Every time I say this is the last BOMB, something else pops up. :D Then after the DV's, I'll have to go with an HX-40, (or bigger). Does it ever end?:D
Jim
Originally posted by Rams-n-Hogs
Thanks, Jim
Jim
Sure it ends. When you're toes up at room temperature!:D :D
