Dave,
I think I had one of the very early Horton's designed for the 24 valve engine. They did have a metal bracket that was used to hold the wiring harness as it went through the fan shroud and held the wires as they attached to the fan. I think since then that the metal bracket is no longer used. If so, it's a good thing since my fan managed to hit that metal bracket and drive it into the radiator. Luckily, a local dealer replaced the radiator and Horton fan since it was a Dodge part at that time.
I think they've re-designed that part now. If not, be very careful how much clearance you have between the fan blades and the bracket.
Also, the wiring to the fan makes it a little harder to put on a new fan belt... you'll have to unplug the fan to get a new belt past the wiring.
Lessons from the school of hard knocks...
--Phil
--Phil
