HOT JUICE or TRIPLE DOG
04 Exhaust Brake - Down Pipe - 4" pipes
Rocks from tires chipping paint !!!!
i am actually just looking for whats the safest for my truck. . I have an 05 dodge with AFE stage 2 and thats it dont want to go to extreme just want either the HOT JUICE or BULLY DOG CRAZY LARRY version some one told me EDGE is better because it does timing and duration, where bully dog is just a pressure box that involves bumping up the fuel pressure and causing problems with the injectors sometimes. i just want the safest for me truck... I am wanting to get as much input as possible... . So PLEASE HELP THANKS
Hot Juice and the Crazy Larry are pretty extreme for any stock truck. What transmission do you have. Both of these choices can toast an auto trans or slip the clutch fairly easy.
You should consider the standard Juice/Attitude or Standard programs on the Bully Dog Triple Dog. The high versions on both would do nothing much except produce a lot of heat, make you transmission/clutch scream and probably pull fuel pressure to 0 a lot on the LP. Unless you are planning on spending $5,000-$10,000 on additional mods, it would be kind of a waste. Just my . 02.
Well give me about a week or so and I will give you my personal experience. I have had the HOT Juice/Attitude for a while now. Stacked an EZ and have all the upgrades done in my signature. It is a good combination, how good still not quite sure. I am in the high 13s now. I think if I could get passed the rev limiter it would be close to mid 13s, just flattens out at 3200rpms toward end of 3rd and just maintains thru OD and 1/4.
I have the BD Triple Dog, just waiting for the Update Link on the web site to be turned on so I can download the "Crazy Larry" program. Then I will try the BD w/CL and see how they compare.
