hot juice stack
Any info on AMSOIL OIL FILTERS?
nv5600 oil change?
I don't want to get rid of my edge juice. I have a rivalry with a d-max. He has the new PPE and his truck is fast. What can I stack with the juice so I can kick his *****. I will be doing my transmission in a few weeks.
Also my hot juice pegs the egts fast. Is that my relief valve or because I am running the rail dry? Will a pressure box stack drop the egt's?
Your not running the rail dry with that juice. You gotta start thinking outside the "boxs" if you really want to show him what a CTD is made of. Your EGTS are climbing so quickly for one reason... a lot of fuel... not enough air. If you were to change out that turbo, you would watch those EGT's drop just like your buddy's pants after you got done rappin him and his dura-cra*. Just some food for thought...
Cstrafa
ha ha, thats funny, but your hot juice can run the rail dry it did it on mine when it was stock, any way a turbo will help you tremendously. if you want a good burst of power get a good pressure box at around 75-100hp and that will work really well. your stock transmission will not handle any of this power effectivly. you need that race transmission we were talking about, i would suggest a van aaken pressure box with the race transmission, and a fass. a sps 62 would also complement the combo perfectly---and best of all it will make over 550hp and be very streetable, i have had similar comboed trucks, they run very well. Oo.
I stacked my HOT Juice with an EZ, this combo was very good. I did have FASS and II SPS66 to support the stack. The EZ will actually lower EGTs a little and help bottom end. But with out at least upgraded LP and turbo you will not be able to take advantage of the HOT Juice stacked with anything. My stack dyno'd around 480rwhp and ran consistent 13. 8s 1/4s. That was on 315s at 7400lbs.
BTW, you need built tc/trans if it is 48re.
