Hot juice vs Powermax?
Turbo
bully dog bully box
Are you running a rail pressure gauge on yours? Is that where the problem lays, just running the rail dry? Mine are extrude honed, not the edm's not sure what if any difference that makes.
SOTP and independent test on my country road track;) it runs very similar to what the truck did with the quad box on 100hp, smaller turbo and factory injectors.
TST also has a middle of the road program they don't advertise much. They made it for the 04. 5 guys that didn't like the agressiveness of the twin flash. It ramps to max fuel around 22 psi IIRC. That may be a good option for you but I havn't tried it. If you step up the the 66mm wheel the twin flash would be alright but with the big sticks on that tight turbo I'd stay with someting less agressive.
Does the r47 run the twins program? Turbo will be upgraded. I thought I had the 14, but was mistaken. What is the less aggressive program number?
