Hot rodding 24v in a fl50??
gvwr questions
what would you charge
What is out thier for programming etc for the 5. 9 that is in the fl50's
I am looking for something more then an ez too. The truck will be around 350-400 hp is the goal and will have a set of towing twins on it if we do it. Was looking for a p-pumped truck but this one is a pretty good deal
what is ouy thier?
Thanks Travis
I don't know what voltage range their MAP sensor has. But, I would bet if it is within spec of the sensor in our application you could make a TST Comp box work on it. I am pretty sure it is the only box that could be engineered to fit.
You should also be able to run the same injectors as the Dodge application. ex, Mach series injectors. But you will need to do boost fooling. The TST box will take care of that if it will work.
I would love to hot rod a small (a "short bus") school bus with the 5. 9 to mess with people. Make it run mid to low 14s :-laf I can just see the look on peoples faces as a school bus hangs with their mustang :-laf
I am assuming you have not bought the truck yet? Beware of the 53.
53 does not scare me, Alot of the big schied motors are 53's :)
Apparently the tst will work
Now lets see what the bank can do
I am thinking tst some mach maybe 2-3 and a 3b under a 40 :)
and get my buddy up at south bend to freshen up the clutch
Travis
well the deal was too good to be true, so good that someone else gobbled it up before i could get back with the guy
Oh well I'll just hafta look some more!!
Travis
