Hello again. Another bit of info about the P7100 pump: the plungers are rotated by the rack from the governor, the same plungers that are pushed up and pulled down following the lobes on the pump camshaft. The barrels are indexed into the flange assembly which is held down to the pump housing by the two nuts on the top of the pump on either side of the delivery valve holder (the splined piece in the center of the flange that the injection line connects to). You will notice that there are shims under that flange between the flange and the pump housing. These shims are there to allow the pump technician to adjust the startof injection of fuel to that cylinder while the pump is on the test stand. Under
no circumstances do you want to loosen the nuts holding the flanges as the fuel delivery to that cylinder will change and you can over/underfuel a particular cylinder or you could lose the shims and get the timing out of spec! Engine damage will result!
Don't be concerned too much about the end of injection, as it changes when the quantity of fuel being delivered changes. The start of injection (static pump to engine timing)is of primary concern. The time of burn of the fuel/air mix usually is a fixed amount of time. As the engine speed is at idle, if the pump to engine timing is optimized for this engine speed, if you run the engine at wide open (example: 3200 rpm), the injection timing could be late. That is, in order to utilize all the btu in the fuel to make power, the start of injection has to occur early enough so that the burn time of the fuel, from the start of the burning of the fuel to the end of the burn, occurs so that the expanding gases can use all their force in pushing down the piston to make power. As you increase engine speed, you have to advance the start of injection to optimize the burn for complete utilization of power. Of course emissions, etc. enters into the mix, but that's a whole new ball game.
With the P7100, the static pump to engine timing is a compromise for the most power while still allowing for easy starting even in cold weather as there is no timing advance mechanism incorporated into the drive of the pump.
The VP44 comes with a timing advance mechanism built into the pump (controlled electronically) much like that of a gas engine distributor, only this one is hydraulically operated instead of vacuum operated. This can allow for retarded timing for easier starting, and advanced timing during operation to reduce emissions and increased power.
If you need further info, feel free to PM me... .
Hope this doesn't muddy the issue for you...
