How/what do you guys do about hooking up your generator in an outage? We are really fortunate here so in the 43 years I have never really needed a generator.
Since my son gave me a good 5k unit this past summer I am planning on setting it up for a "just in case"
My plan is to leave it in the shop and just back feed from my welding circuit rather that attaching at the main pole and deal with the snow, dark or whatever weather. Can I do this and just shut the main breaker off and any others that I can't always run? I have both plugs and some 10 gage wire I plan to make a short cord out of. What say the electricians?
So you have a cord with a male plug on each end, one for the generator and the other into the house electrical inlet?
Mine has what I would liken to about a 20’ RV cord, it has four prongs and twists and locks in the generator. The other end has four 120V outlets on it. The actual generator can also be used without this cord, and has some duplex outlets on it. My cord is passed through and sandwiched between some beach towels through the kitchen window.How/what do you guys do about hooking up your generator in an outage? We are really fortunate here so in the 43 years I have never really needed a generator.
Yes, don't stick your tongue on the prongs, Lol...yes, kind of dangerous and probably not code....The new system I am talking about will also be both male pugs.
We live in BFE and are dead last on the priority when the power goes out,
The shop is about 150' away from the house so I think I am ok t
I am not sure if it affects the generator when it comes to reversed flow, but outbuildings with subpanels typically have the neutral bonded back to the main panel. This is to prevent electric shock from appliances with motors, etc.. as it prevents electracy to pass thru the neutral back to the other panel. Make sure you have all wires (including the ground) connected properly)
GCroyle, I live in Erie, PA; right on the Lake Erie - my house is two miles from the lake. Standing on the shore in the winter with the wind blowing will make your eyes water.
