Competition how did i do
Competition beat my 1st mustang
Competition Which gear?
i was at a local truck pull this weekend and everything went right unlike last time. i took third place in stock class. i got beat by a 04 duramax and a 2000 V8 dodge both were extended cab trucks. i think i had plenty of power but i only had smoke come out of my pipes when i took off and had 20 lbs of boost going down the track. does this sound about normal or is there something more i can do for next time. third place isnt to bad for my first time out though.
Good job, but definately, you have a loose boot or something.
43# on the street, should be more on the track.
Get that fixed, you should smoke all gasers. Oo.
NO, I am in 4th low with my six speed. As soon as I can keep my head from lifting, I am going up a gear. Last time out, I made 45 psi, and the old girl peed a little coolant out of the head gasket. :(
Prolly was pulling 2nd low. My clutch wouldn't hold 3rd low. My truck always hit the governor, and then go to work when the sled came up. I need a better clutch to pull a better gear. If he was on the governor then the boost would be down.
Sounds like you pulled pretty well. Need a good clutch(ie mitchells) and a higher gear(3rd) to get around a new d-max. A buddy's dodge v10 auto would always outpull me. But he would never just go the ground speed I had too.
Mine just stays hooked to the trailer now. I'm scared of broken parts now:eek:
Michael
I have fear, specially when I drive a couple of hours to a pull, pull the pulling truck, and need to get home. My 200,000 mile, 11 yr old mule is showing its age. Besides it ain't worth hooking my old 5 spd against new late model high horse auto trucks. They will smoke me every time. But I can run with them down the interstate!!!:D
Michael
Hey Michael if you keep doing burn outs with that trailer hooked up you might be looking for a ring gear to . :D . That looked pretty cool the other day when you pulled out onto the track & turned up some dirt while rowing through the gears. You sure you can run with me down the interstate?Maybe we should have a tow rig drag race :-laf .
Kurt
Man kurt you are an instigator!!:D
Yeah I can run with you down the interstate. Remember the speed limit is SUPPOSED to be 55 in Il and 65 in Iowa. I can pull with you at those speeds!:D Now if your talking much over 75 then I'll just let you win! Sure hate to show up your truck with the setup you have. :-laf
By the way, no tires were smoking so it wasn't a burn out, just lacking some traction!!
I tried to pull on Friday night, and was posponed due to rain. Went back Sunday to pull. Just before our class the sled broke and was unrepairable! Two weekends I have drove about 2. 5 hours and still haven't hooked yet this year. :rolleyes:
I'll try again soon though!
Michael
