Ok guys, I replaced my IAT sensor a couple of days ago and all is good.
But then I decided to reset the APPS with the voltage reading I got off of pin #23, which means I had to unplug from the ECM. It was reading . 460VDC and the APPS said it was . 568VDC so I adjusted the APPS and had the key on and off a ton of times until I got it set. It is getting lots better milage since I did all of this but I still have the codes it set when I took it apart or unplugged it. :{ What do I need to due to remove these codes. Can it be done with out getting a hand help checker to erase them. I have started if about 20 times since I did all the work and they are still there, so they did not go away in time as far as starting cycles go.
