rbattelle
I had a chance to give the LSD a good testing today when I got one wheel on wet pavement and the other on ice. I used to think this was a good torque biasing differential, now I'm not so convinced it's that good. I purposely hung up one wheel (happened to be the right rear both times) on two different snow banks. The other wheel was on wet pavement. Both front wheels were clear of snow/ice, but were on wet pavement. Nearly-level ground in both cases.
On the first snow bank, I could not move the truck without 4wd. I was completely stuck. I put it in first, put the RPM around 2000, and pressed the brake pedal to the floor. No lockup. The wheel in the snow happily kept spinning.
On the second snow bank, I was able to get the other wheel to engage with about 50% brake application (that's a lot of brakes!).
I found this a rather paltry performance. Question: should I have used the parking brake instead of the service brakes?
