yep. . get a wide stone chisel and a malot/sledge and lightly tap it to score the surface. then give 'er a real good hit. if the score is good and the chisel is wide enough, it will crack right in half. . you can also use a masonary cutoff wheel in an angle grinder or circular saw. but either way WEAR SAFETY GLASSES. you don't want a piece of stone flying in your eye. .
