How do I know when truck is in regeneration?
I've read that there is some smoke coming out of the exhaust.
on mine you can tell just by listening... alot deeper tone at takeoff, when you slow down w/exhaust brake on, it kinda sounds like its fightn against the motor at a stop, and its alot peppier above 22-2300 rpm. but i have an older flash, and a c&c... so it might not be noticeable on the pickups
also, there is a very distinct smell associated w/ it
only w/ a cracked dpf... = trip to dealer for replacement
sag2, how long are these dpf's supposed to last?
Correct on point one. Useful life is about 175,000 miles but that depends on many factors.
I have never been able to tell when my regen was taking place. No change in sound, no smoke, no change in performance. I do not have any guages (EGT etc) that can help me out as my truck is all OEM and no mods at this time still. I had problems with overhead alerts at 8000 to 10000 miles, I would hear that dreaded "ding" look up and see "service needed-reduced power" and that was with no prior warning. took a visit to a dealer for new flash and havent had any problems since then with the DPF regens. Dodge should have put some kind of alert on so that you could know when the regen was happening so you would not have to interrupt the regen. My question is: Does the regen finish from where it left off if you turn the truck off? Too many questions about this issue on the forums... never been adequately satisfied because of all the different replies and dealerships are no help either. One told me it would not work if my cruise control switch was on. . even if I wasnt using it... just the switch being on would stop the regen when needed. Now THAT just dosent make any sense at all!
1. Regen will terminate upon turning the engine off. Regen will not start up again until the system sense back pressure in the exhaust at the DPF.
My truck has never said anything but "System OK". . I put the Edge system in and would highly reccommend it. . You get the boost, the guages and most important you will see when driving down the highway how often it goes into passive regen. . You will also be amazed how often it goes active as well. As soon as you put it in park, the active regen turns off but the EGT's are still real high coming down. I have the turbo timer set at 400 degrees so I walk away, lock the truck and it shuts down when it hits 400 degrees. . this has to save the turbo and add more life to it... without the guage many of you will never know when it's in active regen until your filter is almost full... Sure glad the truck shop talked me into the multi-function Edge product. . taps into your OBD2 port, which is a piece of cake. . I monitor trans temp, turbo boost, egt's and regen...
