I beleive that you can wrap a nail with a coil of wire, and connect to a battery and get a magnetic field which will pick up other small nails etc.
When in elementary grade I did a science project that was similar to what I described (creating a child's copy of a crane), but that was just after magnetic fields had been discovered :-laf , so Ben Franklin and I were working in the same era on this
Today's elementary school students are probably creating magnetic powered robots, space ships etc. , computer controlled that can actually work
From a google search:
Explanation of what the coiled wire around the nail shows:
Electrostatic flux is impeded or blocked by metallic objects. Magnetic flux passes through most metals with little or no effect, with certain exceptions, notably iron and nickel. These two metals, and alloys and mixtures containing them, are known as ferromagnetic materials because they concentrate magnetic lines of flux. An electromagnet provides a good example. An air-core coil carrying direct current produces a magnetic field. If an iron core is substituted for the air core in a given coil, the intensity of the magnetic field is greatly increased in the immediate vicinity of the coil. If the coil has many turns and carries a large current, and if the core material has exceptional ferromagnetic properties, the flux density near the ends of the core (the poles of the magnet) can be such that the electromagnet can be used to pick up and move cars.
http://www-istp.gsfc.nasa.gov/Education/wmfield.html Explanation of magnetic field
http://www.amasci.com/electrom/statbotl.html Science Project
http://www.walter-fendt.de/ph11e/mfwire.htm Magnetism and a current carrying wire
http://www.schoolscience.co.uk/content/3/physics/copper/copch33pg1.html
Magnetic fileds from a school site
