Just like the title says... I need to reduce some turbo noise, I like the sound to a point but when I am in the truck for longer drive times it gets annoying.
cclark746 said:HUH Reduce turbo noise???? buy a gas truck are car
JFaulkner said:factory air box would be the most effective silencer, and easiest since you probably already have one.
And replace it with ???telliott said:you could ditch the AFE, that would reduce turbo noise.
mattymac said:Put in your silincer ring if you havent takin it out (which I can assume you would have already done that) Or put your airbox back in.
LEPage said:And take the "torque tube" off also. The only thing it torques is $$$ out of your wallet, especially on a stock truck.
RustyJC said:If you've been on the road for days at a time towing a 5th wheel, it gets pretty old!
Rusty
Try a Scotty II type intake system that ties into the cowl and maybe you'll rethink that.cclark746 said:Sorry bud i tavel alot from louisiana to colorado pulling a trailer and i just thought every turbo diesel gear head loved the sound of a turbo whistling loud as possible.
