How do you clean used Injectors?
R&R Ball Joints
Banjo replacement --- aeroquip part #?
I got a used set of 275's and would like to clean them. Do I only need to be worried about cleaning the tip? should the brass washer be o. k. to use again?
·1999 2500 QC LB Auto 3. 55 4x4
·Armorthane Bed liner, A-pillar gauges, RE-0880, EZ, Husky mats, strait pipe
Cleaning shouldn't be required. Maybe use some varsol and a soft brush but Do Not use any abrasives such as emery cloth as you could damage the injector holes and alter the spray pattern.
Never re-use compressable washers as they are hardened from the heat and pressure and will not seal the same under the same torque. Get new ones. . This is your baby right?? Don't short-change yourself on important parts. Washer fluid maybe but engine components, don't fool around.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
237,500 miles (380,000 Kms) 7850 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics 07-00
[This message has been edited by Lil' Dog (edited 03-08-2001). ]
Use some lacquere thinner, give them a good soaking. They shouldnt need any cleaning to be honest, but I can see wanting to do it incase. FT Collins I see... a friend of mine Ern Hudson) just left to go out there and head up the investigation unit for the county Sheriff, Alderman I think??
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
Most shops that work on diesel engines,except for maybe a dealer,have injector test stands where they can check the opening pressure and spray pattern of your injectors for a minimal charge in less than a half hour. It may be worthwhile to have this done.
For the full injector cleaning and pressure/flow/spray pattern check, my neighbor's shop does the ISB injectors for $16 apiece (Tri Cities Diesel Injection). Without cleaning about $8-10.
