Yeah! It was
The pump had the locking screw with the shim removed & screwed in when I sent it out for leak repairs and when it returned. It seemed a little smokier * less powerful than I remembered, so I did the 1/8" thing on it.
Exhaust is clean, runs great but seems to be putting additional strain on the starter motor when she cranks over. Could it be that 92 degree switch is causing way too much lead when it is cold?? It starts fine after that initial cold morning start.
Almost forgot, I ran it 750 miles just after reinstalling the pump, prior to moving the timing. The EGT's were up there (1400) on hills at 70MPH. It pulled OK, not great. This was without any load in the truck! Hence, my attempt at something which could have been changed from the pre-rebuild?
