How Hard to Replace MAP Sensor ?
6th gear noise under load only
This is what Customer service should be!
What's involved in replacing the MAP Sensor on an '03 HO w/turbo?
Thx. JW Chessell
you need a large socket, 1 1/4" or larger, I can't remember. Remove the sensor electrical connection and unscrew the sensor, I used teflon sealant on the threads of the new sensor and replaced. I did not have access to a torque wrench on the side of the hiway, but I am sure there is a torque spec.
Isn't the MAP sensor the one in the intake manifold held in by 2 small TORX screws?
I pulled mine last weekend, cleaned it, and re-installed it in a matter of 5 minutes with a small Torx screwdriver.
Absolutely, my bad, Sorry to the OP! Was thinking of the rail press sensor.
AH64ID you are one handy person to have around, Thanks for keeping me inline:) Jess
