Currently, DTT transmission, 4" exhaust, AFE, HTBG turbo, Comp box and DDII's. With the box on 5x5... on the freeway(flat) I hit 1325* EGT and 39. 6psi boost max. How much more fuel can I throw and be safe?? I am considering Mach 2's or 3's. Like I said, it only gets over 1300* when on kill... at the maximum. I have seen higher when in the hills or steep grade. When towing, I turn the box down regardless so that is not a concern. This HTBG turbo has been great so far, just want some cleaner, more effecient injectors seeing as my fuel mileage dropped 3mpg when adding injectors and thought the Mach series would be cleaner and cooler.
