I had my valve seet on my 03. 5 drop and cause the valve to put a hole in the top of my #2 piston. How much should it cost to fix? vesus buying a new engine from cummins? ATS is quoting me about $7500 to fix everything and to take preventive measures by putting in oversized valves, o-ringing the head and porting it. And for about $500 more to do an aftermarket cam. As far as fixng it goes they are going to: machine block sleeve #2 cylinder, check all others for good cross hatches, boil block, deck head and block for true surface, hone and clean up cylinders 1,3,4,5,6, and cummins rebuild kit.
(Some of this is a foriegn to me, I just wrote what is written on my estimate)
Any thoughts or advice on my situation??????
