yup thats about what happened to me. i had the smarty on sw9 for the first pull and did 602HP. then for the second and third pulls i added the pressure box in and the second pull was 604HP and the third was 606HP id say my pump didnt even have enough for the smarty alone.
Folks at TST say SW#5 is pushing it (90 HP) to the limit or over with the stock fuel system. Every mod is different, so what might be a problem at just 90 HP with, say, a Smarty, might not be a problem with another mod.
Note, today, I've got it set on SW#0, and YES it is an absolute DOG, but I'm doing a test. SW#3 is a pretty good setup for acceleration that won't tear up your powertrain.
BTW, you might try fiddling with the Smarty, and put it on 7 or even 5 with the pressure box. It sounds counterintuitive, but with the boost fooling the Smarty is doing on the higher numbers, it may be conflicting with what the pressure box is doing. IOW, it's not simple math (i. e. put all the boxes on the highest setting) as the synergies between systems don't always occur at the same relative place on the system curve.
