i just had my rear driveshaft rear u joint changed again about 1,000 mi. ago. currently sitting @ about 65,000 miles. i have some pretty significant slack, or slop in the driveline, resulting in very significant thud and clunking noises, esp. at low speeds and uneven pavement. with the truck in N, and the pressure off the transmission, i can twist the driveshaft by hand and it almost feels as if there is a broken tooth in the rear diff. there is that much play. both u joints are tight. i cannot move the shaft up and down, as i could when the u joint was shot. "clunk clunk, clunk" is the sound that i hear as i drive extremely slow over diagonal speedbumps.
every Dodge i have ever owned has had driveline issues, but this may be the worst i have seen yet.
