How much space should there be between the front spring and the rubber bump stop?
Where to get visor?
leaf spring pins
My truck was to the point where I couldn't put my finger between the spring and the rubber bump stop, so I took my springs to the local spring shop and had them re-arch them and also added a leaf. Now I have about an inch and a half of clearance, but it still doesn't look like it should be enough. I was wondering how much space you guys have who put on the skyjacker 2. 5" front springs...
Steve , I always liked your truck and I am building a '92 W350 5spd with a home made dumping flat bed now myself. . what custom work did you do for your suspension?. . im interested my self i do plow so a plow weighs a ton in th efront too. .
thanks
Deo
thanks
Deo
Thanks Deo,
The only other thing "custom" other than the skyjacker springs, is you need to beef up the mounting plate that the steering box bolts to. (get rid of it) That reinforcement plate that Dodge calls it is not worth its weight in steel. The best thing to rid your self of steering problems is to mount the steering box where Dodge mounts it for the 2WD models, ie, a crossover steering convertion.
Dodge crossover steering Now I havent done that but wish I had.
Steve
