How much torque can the DTT VB & TQ handle?
Who's next?
Oil leak
I want to modify my transmission with Bill K's components. Just wondering how far I can push the torque ratings.
Ray T.
2001. 5 2500,SLT,White Reg. cab,2wd,Auto,4. 10 limited slip,trailertow package,camper package,and ready to bomb. Let the bombing begin.
the limiting torque number is what the TC can handle when locking up , once its locked 900 plus isn't a big problem , DISCLAIMER it hasn't been for me anyways .
i'll Bet bill answer this , but the lockup lining has its limits no matter who's TC you have .
I would also like an estimate of the sustained torque the overdrive planetary gear set can handle. Or what is the maximum boost vs RPM you should have while towing. Is towing at 70 mph and 20 lb boost (200 hp)with 3. 54 gears going to wear out those tiny planetary gears in several thousand miles?
'97 SLT 2500, 4x2 LB Club Cab, auto, 230/605 fuel plate and 215 injectors, pillar mount Isspro gauges, BD torque converter, BD valve body, BD Pressureloc, Mag-Hytec transmission pan and differential cover, 3. 54 LSD, white/driftwood, air dam, sliding rear window, towing/camper pkgs, Rhino liner, SS bed caps, stake pocket tie downs, chrome exhaust turn down, SS wheel well trim, Carr steps, Mopar mudflaps, Aerotank under seat toolbox, Cobra 75WXST CB/Firestik, J-MAC louvered aluminum headache rack and tail gate, Mopar flag/tow mirrors, Reese 15k fifth wheel hitch. Mopar Ram hood ornament, Sweet Tooth grill, and white dice. Kennewick, WA.
Isn't the next weakest link after doing the VB and TC the OD clutch pack... Bill?
'99 4x4 • SB • QC • 3. 54 • LSD • AT • Leather • Mag-Hytech • Westach Guages • Line-X • Tommy Gate
I have been told somewhere around the 500hp mark... but call Bill to verify.
Bob as far as the 400hp mark... I honestly believe that Bills setup will definately handle more power then that... cause Bills truck is around the 400hp mark with the PE on max. . and his transmission has no problem holding that kinda power. LOL (guess it time to add more power... LMAO)
Kev
