Yeah but sythetic is required in the new axles. Not so much in the older ones. Plus most of the 3rd gens have the anti-spin diff so they are a little different. Different enough to require sythetic.
Nate said:1st gen, 2nd gen or 3rd gen... it doesn't really matter. The axles are the same basic design.
Diesel Nut said:I do it in my current truck because I feel that I am very harsh on axles. Between the 20psi 4x4 launches, quick short drives in town, and moisture, and the fact I have 3 or 4 cases on the shelf, its just makes me feel good to know its clean and fresh.
05mxdiesel said:changed at 15k with amsoil and will change the rear every 50k and possible 75k on the front. Amsoil suggests 100k normal duty and 50k severe service for the 75w90 severe gear. 15k to 30k is excessive and gets expensive on a good synthetic lube unless your towing extremely heavy all the time.
Bertram65 said:Not really, the 2nd gen are Dana with a clutch based limited slip, the 3rd gen are AAM with a gear based limited slip.
Did they reconmend 15k fluid changes for the Dana axles?
lil red cummins said:i think the race to change differential oil is a little over done for all but those that push their trucks to the limit.
lil red cummins said:worked on school buses for 7 years earlier in my career. many of our buses were over 10 years of age and over 100,000 miles.
mix of mostly stop & go and a little highway.
never ONCE did we change diff oil and never ONCE did we loose a gear in one of our 34 buses. and this was on regular 90w oil.
also worked on untold volume of cars and trucks of all ages and mileage some up to 700,000 miles.
quite honestly, i have NEVER changed differential oil just to change it. it normally was done during a seal replacement.
for me, i will probably do it on my truck at 50,000 just to see what all the hype is about.
just my . 02
jim
