How often should the fuel filter be changed, and should it be more often with the new ULSD?
bmoeller said:15k or every other oil change.
Rattler said:Also i keep a little notebook in the console and write down dates, miles, and what i did for service. That C. R. S. just gets worse with every birthday. Randy :-laf :-laf
keimmmo said:I change when I see a 2psi drop in fuel pressure at cruise. I have had filters plug in as little as 4k miles! I must have bought a load of dirty fuel!!! Usually, they last around 30k miles.
Acually you guys who are changing your filters really often thinking you are doing your VP a favor have it backwards. The more nearly a filter is to plugged the finer the particles it will filter out... the more efficient the filter. When the fuel pressure drops, that is a worse problem than a new and less efficient filter, so it is time to change.
Steve Keim
