bgilbert said:You already have a Dana 70 for your conversion?
Oh my, where have you been, haven't you been reading TDR?? Yes you need a Dana 70 even for a stock Cummins. That 60 might last a few, but don't drop the hammer, bomb the Cummins or tow with it if you want the 60 to last. Why do you think Dodge used a 70 and not a 60 in 1989 when the Cummins was first introduced??I'm leaving the original Dana 60 in it. Do I need a Dana 70?
bgilbert said:Oh my, where have you been, haven't you been reading TDR?? Yes you need a Dana 70 even for a stock Cummins. That 60 might last a few, but don't drop the hammer, bomb the Cummins or tow with it if you want the 60 to last. Why do you think Dodge used a 70 and not a 60 in 1989 when the Cummins was first introduced??
Heck just pull the rear 70 ad on ebay, say it was sold locally. Then try to sell the 60 rear.
What else are you selling that you thought you wouldn't need?
bgilbert said:Sorry if I came off as a smartbutt. Wasn't my intention. The 60 and 70 are two different axles. As far as technical differences, I suggest you start a new thread, as it will get much more exposure than in this 2 page thread. Something like Dana 60 vs. Dana 70 etc.
HSchroen said:No need to be a smart*****. This is my first foray into Diesel trucks, I'm learning, I thought the 60 could handle it. I really want to keep my 4. 10 gears, the 70 has 3. 54's. And yes, I know the gears can be swapped, but I'm working on a tight budget and need to recoup some of my investment.
Dare I ask, what the difference it between a 60 and 70?![]()
boatpuller said:Unless you are going to tow really heavy or put huge tires on it the 3. 54's will work better with the Cummins, the 4:10's will really limit your speed on the highway. My $. 02.
Caleb
EarlKann said:I did the same thing that I think you are doing. Kept the D60 that was already in the front of my crew and swapped out the rear D60 for the diesel D70. Now my front has 4. 10 and my rear has 3. 54 :{ But... . It looks like I may have just scored a D70 with factory 4. 10 for $300 Oo. Much cheaper that the gear change I was planning on. Keep your eyes peeled in the classifieds and keep checking www.car-part for a 4. 10 D70.
I had to have a whole new drive shaft made for the D70 rear in my crew. The one from my donor was about 1. 5" to short. Mine was a std cab though so your club cab drive shaft may just need to be shortened which would be cheaper.
HSchroen said:My only experience with this is with a 2003 3500 SRW that had stock 3. 73's and 6-spd. It seemed to be a pretty good match... . honestly 3. 54's probably would have worked just as well. On the other hand, the new Cummins makes alot more power (stock to stock) than the 1st Gens... and my '03 3500 was a 2wd, not 4x4.
My thought was the heavier 4x4 of our Crews, coupled with less power, would need the 4. 10s. I plan on pulling about 14,000 pounds... . only on occasion however.
