Intercooler cleaning instructions from the manual below
I double checked the drain tube, removed it and ran a fat screw driver down into the oil pan while reaming the orifice. There are no obstructions from drain to the bottom of the oil pan!
That leaves excessive crankcase pressure or the turbo.
Turbo:
They took the turbo apart, no signs of wear, no wobble, and put it back together for free.
Crank case pressure:
Oil PSI is 40 by the dash gauge. Breather is breathing. Engine idles like she always has. Are there any other signs of momentary excessive crankcase pressure? Seems like the probability of that is very low.
This all started out as a exhaust manifold replacement that turned into something else when I sheared off the turbo manifold bolts and had the turbo rebuilt with a new housing.
The turbo is the only thing that has changed that is close to oil.
After I clean everything up I'll see if shes still spitting oil.
