how to burn carbon off injectors?
Help a young Dodge enthusiast
what the hell?
My last three trucks got 58mph in second up against the governor for about 10 miles or so. It always took the little ticking and clicking noises away. But running with a load will create more heat to burn things off. With a stock truck you should never have to worry about exhaust temps.
Just to clarify a bit... 2nd. . or did you mean 3rd gear?
With all the stuff you already have you might consider water injection for 2 reasons. To keep your EGT's in check and secondly it does rid your engine of carbon.
Did you ever take a Coke bottle and slowly use it to pour water in your gasoline carburetor to get rid of carbon? That was fairly common in the old muscle car days!
Peter
All I can say is 6 min against the governor on a stock truck would not hurt a thing or something is wrong to began with. You ought to be able to do that with a load! I am sure its better for it with the load. Stock truck! I just wish sag2 worked at my dealer and I knew his secret identity.
