How far should timing be advanced ??RJPotts said:I'd say one of the best ways to control smoke is to be as smooth as possible with the go pedal, and advance your timing. -R. J.
Does moving the AFC housing or the Star Wheel have any effect on Smoke ?? If so, HOW ??pwerwagn said:Somewhere in the neighborhood of 16* should suit you fine.
Another great smoke control device is your AFC. If you still have the stock AFC spring in the AFC, leave it, dont buy the TST kit. The stock spring is mo' betta for smoke control.
--Jeff
Katmandu said:I'm getting a set of 370s and a 3k GSK here shortly. (See Sig for mods).
I want to keep the smoke DOWN as much as possible. Although, letting the "Coal Roll" on occasion would be cool!
How does one set the Pump and related parts to keep a lid on the smoke from the 370s ??
?? Where are they located ?? What does this accomplish ??Jim Fulmer said:In stock form the AFC is actually a piece of crap, the two internal washers are in the wrong spots, they need to be swapped..... hint,hint!
Very Interesting... . Homemade unit ?? Got pics ??... . turn the regulator (hand held) to 40 psi
Is swapping the exhaust housing to a 16cm unit on a HX35 considered a "Hybrid" ???Forrest said:2. Bigger fast spooling hybrid turbo.
3. Hobbs Sw the wastegate on the new turbo. Ck with the supplier, but if it's opening early, like around the 20psi's, keeping it closed until the 38 to 40psi adds to the air. Sure decreased my smoke.![]()
Katmandu said:?? Where are they located ?? What does this accomplish ??
