My daddy just recently purchased a 1995 4x4 Reg Cab Auto 4. 11 , that has had some work done to it already. It has stacks, suspect injectors, and a different fuel plate. We are trying to find out what plate is in it. Truck had an old TDR sticker on the tool box. Truck black smokes on start up, but none at idle. Does not smoke through the gears. Looks like a coal train once you hit overdrive though.
Wastegate is gone, completely pulled off and all hoses have been plugged. Silencer ring is gone. Airbox is gone. Long cone shaped K&N filter on it. Has 3 gauge A-pillar pod w/ Trans, Pyro and Boost gauge. Boost gauge only works when you floor it. It'll quickly climb to about 25 lbs then just fall off to Zero. Does not show boost at all going down the road. Only shows when you accelerate heavily. Can not find any leaks. Suspect bad boost gauge. Pyro or Trans gauge do no work either. All 3 gauges are pretty much junk, will probably get trashed as we cannot get them to work.
I pulled the AFC housing off yesterday. The star wheel is turned all the way forward and the fule plate is slid all the way forward. It has a part number stamped on it. Part # 42604 or 46204. I can remember which at the time. Does anybody know what plate this is?
I suspect injectors due to truck sounds like it has a cam in it. It has a miss/sputter between 1100-1200 rpm bad. Soon as you get past 1200 it goes pretty good. Hit overdrive and its gone. We call it the "Go Hole"!
Maybe timing advanced also?
Found 1/8th inch slack in throttle linkage that we eliminated. Linkage bottoms out on fuel pump throttle stop now, but truck still will only runs 85/2600rpm mph on the floor.
Trying to determine what all has been done to it, and what is to do. I don't think GSK has been done due to only runs 85 mph/2600rpm.
Any pointers or advice as to what to check or look for to see what has been done to it or to determine what it actually has in it?
Thinking it needs Valve Springs and a 3GSK and a turbo housing.
How do ya determine what size housing it has now? I think it is stock.
Muchas Gracias,
Muchas Gracias,
