Details here: TDR Privileges
Turn to left 1/4 turn then pull out. Don't be surprised if it comes all the way out. All is not lost, you can re-install, check the O-ring to make sure it is ok before re-install if it does come all the way out. bg
Just did this same job, turn it slighly and then pull it out, may have to use a pliars. Might want to dig out a piece of tubing to go over the petcock...
