I need to fix the ATF leak shown in the photo. It's at the front of the 241LD transfer box near where it connects to the 47RE transmission. I dumped 2 quarts of ATF on the DIL's garage floor over a few months when I went back to the UK, and this is not the way to win friends and influence people.
Is this caused by the gasket leaking where the drops are, or is this an internal leak of some other part? The fluid is leaking from the transmission, not the transfer box. The transmission pan gasket is dry.
I have the factory service manual. Is this repair just a matter of removing the transfer box, and installing a fresh gasket? I do all my maintenance, recently including replacing rear axle seals and bearings, renewing injector sealing washers, and replacing the radiator. However, I'm in the middle of a field with fire ants for company, so I may end up taking this to a shop. Either way, I need to understand what is causing this leak.
Any advice would be greatly appreciated.
Nick.
