OK, first things first. Thanks to Fest3er for putting me on the right track with the wiring. Second, the Abbott-ERA will only work correctly as it comes from the manufacturer (http://www.abbott-tach.com) for trucks with only Rear Wheel Anti-Lock Brakes (RWALB's). It has to be modified per Fest3er's instructions (on another thread) to work for All Wheel Anti-Lock Brakes (AWALB's) due to there being only a single speed sensor from the rear differential on RWALB's and both a single rear and left front and right front speed sensors on AWALB's.
Now for the installation. The Abbott box has four wires coming out of it: Red (12v ignition switched power) Black (chassis ground) White (in from speed sensor) Blue (out to Controller Anti-Lock Brakes [CAB]). The wires from the speed sensor coming into the CAB (an electronic box attached next to the brake master cylinder with a large multi-wire connector coming into it) are a white with violet tracer W/V and a red with violet tracer R/V. The Abbott manual indicates that the wire with the highest ohm reading (to ground) is the one to splice into. That is the red with violet tracer R/V and is (luckily) one of the wires on the top of the plug. Cut this wire and attach about a 4 foot piece of insulated, two conductor wire with the R/V wire coming from the speed sensor to the white wire of the Abbott box and the other end of the R/V going into the CAB to the blue wire of the Abbott box. I tapped fuse number 8 for power.
The directions supplied are pretty clear about how to calculate the correction ratio. In my case the stock tires went 681 revolutions per mile (you can find this info. at http://www.tirerack.com for most common tires) and the new ones (see sig) go 600 revolutions per mile. The ratio of 681/600 is 1. 135. Looking this up in the table supplied in the directions shows that the closest one is 1. 140, this is what I set the DIP switches to inside the box. I verified the correct MPH using a GPS unit and it is spot on.
Hope this is useful to others out there. Course, there goes my excuse... . yes sir officer, I just put these new tires on and my speedometer ain't right
... . FYI, Rickson is selling a new unit that works with AWALB's that doesn't need to be modified before use.
