2nd Gen Non-Engine/Transmission how to kill my truck!
Engine/Transmission (1994 - 1998) Turbo Boost
2nd Gen Non-Engine/Transmission Hard Steering/ Ball joints
[QUOTE =fest3er; At 12 years old and unknown miles, one should be prepared to replace *all* suspension and steering components,
N[/QUOTE]
andy is a buddy of mine and I believe the truck is in the vicinty of 200,000 miles and lead a very hard life before he bought it.
sounds like XXXXXX is the one who needs a shrink. :-laf:-laf:-laf
I'm placing my bet that your front coil springs are SHOT. :cool:
Worn coil springs will make a truck "wallow". When it "wallows" it will play havoc with your front end components and/or alignment. This very well cause the dreaded Death Wobble!
Was your castor set to 5 degrees when it was aligned? That is a huge factor in the death wobble. After I put the Kore kit on mine it wobbled on a couple of bumps near my house. Not big bumps, just the "right" bump. It had never done it before and the only change was the taller springs, lifting the front end reduces the castor considerably. It was at 3. 5 degrees after the last alignment prior to the Kore kit.
