Someone tell me why this would or wouldn't work.
If you want to measure the amount of caster on any vehicle (like my 01 dodge for example) perform the following:
1. Park on a level surface with wheels pointed forward.
2. Using a level, place it on end right behind one of the knuckles on the front axle (making sure it is standing straight up).
3. Using a tape measure, measure the distance from the level to the center of the top balljoint stud and record it.
4. Then measure the distance from the level to the center of the bottom balljoint stud and record it.
5. Then measure the distance between the two balljoint studs from each previous measurement location (for example the end of the studs).
6. Use your math skills to calculate the caster angle.
For example, if you do the drivers side of your vehicle, top measurement may be 8", bottom may be 8. 5", with a distance of 9" between. Use the following formula: tan^-1 ((8. 5-8)/9) = 3. 17 degrees.
If it quits raining, I may try this tonight on my truck and see how it compares to my alignment sheet.
If this does work fairly well, I won't need to get alignments anymore, just do it all at home
