Competition HP record for stock turbo?
Off Roading Inspired to reach new heights!
Competition Alaska Drag Racing this coming weekend..
Just like it says in the title. Whats the most HP someone has layed down with the stock turbo, 12v, 24v and 24vCR?
Dave
Dave
You have to remember that between those diffrent years/models they came with diffrent variations of turbos that they came with stock, which affects HP output.
Jim Fulmer said:
496hp with a stock HX-35/18. 5... ..... NO N2O... ..... 446 on #2, 496 with Water/Meth.
Jim
Thats what I am looking for but I would like to see what numbers everyone has come up with in different combinations with the factory turbo.
The reason for this thread is a friend and I have a friendly bet on who can make more HP on the stock charger (both 215 pumped). He just dyno'ed 428 on #2 and I am awaiting a new clutch be4 I hit the dyno.
Dave
Local guy hit 492/968 in a 06 with just a TST and bully dog (stock charger)
CR Cummins 2006 Dodge 2500 492. 6 983. 9
thats from t/s event on dunbar dyno
I did 516/1117on a stock charger just with big exhaust and a edge hot juice. I also had to recently replace the stock charger, they don't hold up well to big power.
I think you might wanna get that dyno checked, or your numbers corrected. that seems WAY to high for just hot juice.
beanman said:
There was a bunch of people who watched my truck on the dyno, It seems high but I also have a friend in denver that had his truck dynoed on a different dyno and he put down 495/1060 with just a hot juice. I also found the results from when I dynoed last, I am listed as Marc B.
http://turbodieselregistry.com/forums/showthread.php?t=158900
Curious if the 5" and AFE are making hte difference, or the fact that you have a push pump and I"m still on my stock lift pump...
or. . Hi tech's dyno is making low numbers.
you running the 35" tires on the dyno as well?
BTW, my 422 was with out an EZ at the time. It's gota be a dyno difference or elivation + dyno difference to make 80hp difference with 2 trucks configured the same for hte most part.
I have driven other trucks setup like mine with 4" exhaust and the seat of the pants feel is definatly alot different. And yes I run the 35" tires on the dyno, I can't afford an extra set.
I was always told my regular Juice stacked with an EZ puts out around 180 RWHP, same as the hot Juice and I put down 436 at the rear wheels with 35's
