HP without Electronics
where is everyone putting there pyro?
cp3 flow numbers?
lmills said:
Now I need to get to work on my "entirely mechanical boost fooler" and tone ring/crankshaft sensor mod for timing so I can put this to rest :-laf
Uhm. Just screw a fitting to where your map sensor goes, put a 15PSI pop-off valve, then screw in your MAP sensor into that. ? Non-electronic sounding to me.
Of course you can mod the tone ring too, that's non-electronic.
Is nitrous or propane being considered "electronic?
Merrick
I installed KAX injectors in mine at 22000 miles they are modifyed stock injectors nice increaces in power they say 125hp not sure about that but really like the extra power as well as 1 to 2mpgs. The point is they are stock. So should not raise to many RED flags. I be going with a SMARTY soon as I hit 100K as you will see that wont be long. RANDY
