Engine/Transmission (1994 - 1998) Hp??
Engine/Transmission (1994 - 1998) trans not staying in lockup
I finally got a set of 370s in the truck. It runs really good now but is a little jumpy below 1500 rpms. Does anyone know at about what Hp I would be at? I dynoed 286 hp and 868 ft lbs at schieds before the injectors and gsk. Also would anyone know how much fuel a plateless 215 pump with the 370s puts out?
Kron
Does a stage III HTT keep it cool, out of curiousity?
When you dyno'd 268, you had the plate out? You should have made more than that.
With 370's, a 0 plate in the right location, timing, GSK, and enough air to cool it, you should be toying with 450hp, give or take based on your specific condition, the dyno you are using, etc.
It does a pretty good job on keeping it cool. Ive towed once so far with a 26 foot gn and I didnt have any problems. On the hills all I did was back off and let it coast and the highest temp I saw was 1250.
Wow, thats not bad at all.
Mine, with a 0 plate and nothing else, gets freekin hot with the stock 35. Like, it will peg the pyro in no time. If I keep my foot outta it towing, its acceptable, but I have to take it out of 5th a lot on the hills.
--Jeff
