The hub really isn't tight in the knuckle until the rust scaling fills in the gap. It's nuts.
I got a good tip from DTR on the ball joints that worked. I cranked down on the third ball joint press (rented that one from Auto Zone) with the impact where I could use it and the 1/2 breaker where I couldn't. After I cranked down I whacked the press shaft right on the tip with a short 5lb sledge. That popped them loose. Then, crank down again and smack. Crank down, smack. The lower wouldn't give up until the last 1/8". The uppers both only needed a couple of smack before the impact walked them out. I used steel wool to clean up the holes and then pressed the new ones in, with a good cover of anti-seize on every contact surface on the whole front end. The u joints worked with the same principle. A 5 ton jaw style puller, with a sacrificial socket for even pressure on the caps, cranked down; then smacked the yoke with a ball peen hammer and they popped down a little. Then recrank and smack, then walk out with an impact.
Now that I've done my first, the rest will be easy.
