I thought the Hummer used the same American Axles as the Dodge so would have been a direct fit?? They look nice on your truck. The cast Dodge wheels aren't that bad but the hub cap ruined the look IMO.Originally posted by bighammer
I picked up a set of 03 center caps that are painted instead of chrome. I'll turn those on the lathe to make them fit.
Originally posted by Matt400
BTW I see you disabled your "key in" chime. Did you do it at the key tumbler and do you have the factory centry alarm with the chip in the key?
Hrmm, I thought doing that may disable the chip key function.Originally posted by bighammer
I clipped a wire at the base of the steering column. Yes I have the chip key.
Originally posted by rhino_50
Bighammer Do you have a leveling kit on you ram pick up? Do you think you need it with the hummer wheels and tires ? thanks Rhino50![]()
