Engine/Transmission (1994 - 1998) Hummmm, really thinking about the 4500 to 5600 swap...
Engine/Transmission (1998.5 - 2002) Tach question?
Engine/Transmission (1998.5 - 2002) new lift pump idea?
for my 97' 3500 4X4..... if I have to spend the $$$$$ on a fully splined mainshaft for the 4500, why not just anti up for the 5600? My question to this forum is what other parts/pieces will I need... ... . clutch ????? Re-route the exhaust system ????? Mounting hardware ????? Any help would be greatly appreciated:)
Thanks again for a great forum
Christian Ray
Hendersonville, Tn.
There is an article on someone doing just what you are talking about in the new TDR Mag. I just got in the mail. Even has costs.
Cray,
Jim Leonard has done a number of them, including the one on his own truck. He can do it in a day. I think all you need is a different crossmember from Dodge, and a shorter driveshaft in the rear and a longer one in front since the 6 speed is 6 inches longer. Give him a call. His number is in the back of the TDR magazine. He is a very knowledgeable and helpful guy.
Bob
I'd like one for my truck too, but $6K for the project is a lot of coin! I think I'll wait until I can get one out of salvage or a rebuilt for less? coin.
Good luck!
I'd like to get one too, but $6K is a lot of money for an extra gear! I hate the 3/4 split in the 5 speed, but I don't know if I hate it that much!
Good luck
They have nv5600 transmissions on ebay for $1700 plus your core!! Nv4500 are around a $1000. What is the plusses of a nv5600? I heard the 1st gear and last gear in both trannys are the same. One more gear seems to just make the truck slower. Also I am just curious, but is launching in 3rd gear an option?
Somebody here on the TDR has (or had) 5600s for sale. It's a recent post.
Before I replaced my clutch, I thought I wanted to swap my 5 for a 6 speed, but now I'm glad I didn't. I got to drive a truck with a 6 and didn't like it much. Gates are close and it's not as easy to shift as mine.
If get a governor spring kit, the 3-4 step is not so bad. Now I can wind up a bit more before I make the shift. I seem to be keeping the RPMs up a bit more just because I'm not hitting a wall at 2100 anymore.
Blumenthals has a kit (and the trans) for the swap. You might check into that if you do it.
I'm not sure, but I think the frame crossmember, clutch, slave cylinder, and transfer case linkage are different. The driveshafts have to be altered. (6" shorter for rear, 6" longer front)
for $6000...
enough extra "useable" horsepower could be had to negate the need for an "extra" gear (with a little $ left over).
That is just my opinion. Six speed transmissions are nice.
I have two trucks one with a 6spd and one with a 5spd . I would say I like the 6 best for pullin and the 5 for regular empty drivin. I would suggest the 6 if your allways pullin or loaded heavy, but if you don't pull that often or what you pull isn't all that heavy I would suggest stayin with the 5 for both cost and eas of driving. Just my two cent's
Seth
